I have a polymer system with cross linkable end groups. I would like to cross link the system during a run but only allow a defined number of cross links to form. By that I mean, if there are 20 places that could be cross linked, I would like to only cross link 10.
Is this something that would likely be controllable using an “if-statement”?
If you are using the fix bond/create command to do the
cross-linking, then you could put a series of short runs
in a loop (see the jump command doc page), and
use the if command to test on the # of bonds created
(an output from the fix bond/create command), and
exit the loop when your condition is met.
