Bond/react usage problem in the latest lammps version
Hi there,
I’m having some problems(The chemical reaction did not trigger) with the bond/react command in the latest lammps version (23Jun2022_update3). But chemistry triggers normally on older software versions (29Oct20). The input file is as follows.
Anyway, thank you all so much for your time and help.
Zilin
data_2chp.gro2lam (17.0 KB)
in.lmp (1.2 KB)
rxn1_stp1.map (295 Bytes)
rxn1_stp1_post.data_template (2.2 KB)
rxn1_stp1_pre.data_template (1.9 KB)
I would be surprised if those reaction templates worked with a previous version. It looks like you are missing hydrogens on template atoms 4 and 14
This problem has been solved. :grinning:
Thank you, Mr. Gissinger
