Dear lammps users,
I confront the error, “Segmentation fault (core dumped)”, when I use the bond_style table command. Besides,it is found that the computation is stopped at the line, “bond_coeff 1 bondLength.table bondHAM”. The help is really needed to find the solution to the problem, because the same error always appears in spite of my carrying out the simple test, whose bond tabulated potential, input file and data file in use could be downloaded from the attachment. And they are (a)bondLength.table, (b)in.BondTableTest, ©testModel.data, respectively, and shown briefly as follow,
(a) bondLength.table
Bond potential for harmonic
bondHAM
N 760
1 0.01 288.3872 152.2996
2 0.02 286.8662 151.8991
3 0.03 285.3492 151.4986
4 0.04 283.8363 151.0981
5 0.05 282.3273 150.6977
759 7.59 284.4983 -151.2735
760 7.60 286.0130 -151.6740
(b)in.BondTableTest
units real
atom_style full
log log.testModel.txt
bond_style table linear 760
kspace_style none
read_data testModel.data
neighbor 2.0 bin
neigh_modify delay 5 check yes
compute new3d all temp
compute my_pressure all pressure new3d
fix 1 all nvt temp 298.0 298.0 100.0
thermo 500
thermo_modify temp new3d
thermo_style custom mass lx ly lz temp pxx pyy pzz
reset_timestep 0
timestep 1
run 20000
print “all done”
©testModel.data
LAMMPS data file
2 atoms
1 atom types
1 bonds
1 bond types
0 angles
0 angle types
0 dihedrals
0 dihedral types
0 impropers
0 improper types
1.084406 51.598243 xlo xhi
-0.556915 49.956922 ylo yhi
1.551852 52.065690 zlo zhi
Masses
1 68.1198
Atoms
1 1 1 0.000000 28.312627 4.731786 41.196543 0 0 0
2 1 1 0.000000 28.892508 1.482578 39.845297 0 0 0
Bonds
1 1 1 2
bondLength.table (20 KB)
in.BondTableTest (498 Bytes)
testModel.data (397 Bytes)
