Dear Lammps-users:
Recently I’m trying to use fix-gcmc command to simulate the absorption of H2 on Pd cluster with
the Reaxff potential. But after only a few hundred steps I encountered the error: “bondchk failed”, then
according to the lammps users mailing list I tried a few methods to avoid the error, but finally I came
to the same error no matter which method I tried.
The methods I have tried are as follows:
Change the value of neighbor command;
Add the mincap and safezone keyword and change their values in the pair_style reax/c command;
Change the parameters of fix-gcmc command, such as N, X, M, random seed and chemical potential;
Add fix-NVT command to combine GCMC with MD or not;
Change the size of the initial system.
The lammps version I used is 10Aug 2015, and my operating system is Redhat CentOS 6.5. Enclosed
are the input script and the data file. I have checked the input script for weeks, but I still can’t figure out
the above error. I would appreciate it if anyone could give some hints to me. Thank you!
Sincerely,
Sen Zhang
in.pd (1.02 KB)
data.pd43cluster (4.04 KB)
Dear Lammps-users:
Recently I'm trying to use fix-gcmc command to simulate the absorption
error: "bondchk failed", then
1. Change the value of neighbor command;
2. Add the mincap and safezone keyword and change their values in the
3. Change the parameters of fix-gcmc command, such as N, X, M, random
4. Add fix-NVT command to combine GCMC with MD or not;
5. Change the size of the initial system.
there is one important method missing in this list: try with the
latest development version (14 May 2016 at the time of this writing).
there have been significant improvements to bother reax/c and fix gcmc
since last summer.
weeks, but I still can't figure out
please note that these are useless without the matching reax force field file.
