Bonded atoms far aprt in Coarse-grained simulation
So if you are adding a dihedral term to the force field and it is causing bad
dynamics, then the dihedral term must be causing it. Where
did you get the dihedral term and its parameters? Is it from
the literature? Have others run good dynamics with it?
Or did you come up with it yourself?
