I guess so far we can only create the region with existing shape options. Any geometry beyond those options have to be created externally and read in via data file? For example, a sine / cosine wave-like boundary for a cube.
Please confirm.
Thank you.
The create_atoms command has a “var” option to define
an atom-style variable that is used to choose yes/no whether
an atom is added. An example of using it to create a sinusoidal
(bumpy) surface is illustrated on the create_atoms doc page.
A little confused about the following example
> variable x equal 100
> variable y equal 25
> lattice hex 0.8442
> region box block 0 $x 0 $y -0.5 0.5
> create_box 1 box
> variable xx equal 0.0
> variable yy equal 0.0
> variable v equal "(0.2*v_y*ylat * cos(v_xx/xlat * 2.0*PI*4.0/v_x) + 0.5*v_y*ylat - v_yy) > 0.0"
> create_atoms 1 box var v set x xx set y yy
In the expression, if “xx” and “yy” were to represent the real position of atoms in the expression, why they were first set equal to 0.0?
variable y equal 25
lattice hex 0.8442
create_box 1 box
In the expression, if "xx" and "yy" were to represent the real position of
because they need to be defined as variables. the create atoms command
cannot use variables that don't exist, it will then override their value
with the corresponding lattice position. please re-read the section of the
documentation. if you think it through, it will make sense.
Totally got it now. Thanks!
