Hi:
I will use the pair_style born which has the following form in LAMMPS manual, the last two terms have opposite mathematics operators, “-” and “+” respectively, and in the examples of this manual, C and D has the same sign.
When I do my calculations in LAMMPS, if I set the D as negative numbers,
pair_coeff 1 1 0.2640625 0.317 2.340 1.05 -0.5
pair_coeff 1 2 0.21125 0.317 2.755 7 -8.6875
pair_coeff 2 2 0.1584375 0.317 3.170 72.5 -145.625
the calculation comes up with " nan";
and if I set the D as positive numbers, the calculation can go down.
pair_coeff 1 1 0.2640625 0.317 2.340 1.05 0.5
pair_coeff 1 2 0.21125 0.317 2.755 7 8.6875
pair_coeff 2 2 0.1584375 0.317 3.170 72.5 145.625
Well, in some other references, the last two terms have the same mathematics operator, and also do the corresponding C, D coefficients, as follows
So, I wonder that maybe there is something wrong in the manual file.
I would appreciate your help!
Thank you very much!
Jia Wang
