From our simulations using non-periodic dimension, we observed
simulation results were quite different depending on the starting
coordinates dimension. Our aim was to fold the stretched peptide into
folded structure.
[case 1] Initial x, y, z-coordinates min/max, i.e. system dimension,
is all wide for x, y, z-dimension in lammps.data file
-3.3994429 40.641 xlo xhi x-dim: 44.0404429
-1.6777038 26.052 ylo yhi y-dim: 27.7297038
-52.796 1.6692155 zlo zhi z-dim: 54.4652155
[case2] Same stretched structure as in case 1, but has different
origin thus narrow z-dimension in lammps.data file
2.496995 65.1194942 xlo xhi x-dim: 67.6164892
0.839991 40.7689475 ylo yhi y-dim: 41.6089385
-2.13122 2.1312148 zlo zhi z-dim: 4.2624348 ****
The z-dimension in [case2] is confined in a restricted
extent; In fact we expect this initial dimension information is
adjusted by LAMMPS during simulation, however for the given the same
simulation time [case1] folded into globular shape quickly, whereas
[case2] didn't fold at all and yet stretched.
Is it possible that "boundary s s s" might prevent a drastic
dimension change thus be stuck in a limited dimension?
Thanks for your help in advance.
