I am interested in calculating the force between the indenter tip and the substrate. I have used lammps_1Nov2013 to obtain the force_displacement curves in my system. However, when I increased the number of atoms, the curves is more fluctuant. I am unsure whether my approach in using compute group/group is the correct way or not ?
In my example system, I have two block copper, one is indenter and one is substrate. There are the LJ potential between two block copper.
You can find the input script in the attached file.
for your specific setup, wouldn't it be simpler to use compute/reduce
to determine the net force on the indenter?
I used the command
compute force indenter property/atom fy
compute fatoms indenter reduce sum c_force
And I found that the result is the same with the case I used the “compute group/group”, you can see the data in attached file.
So now I don’t know why the force-displacement curves is more fluctuant with increasing number of atoms.
Thank you,
Vào ngày 1:52 Thứ Ba, 7 tháng 1 2014, Axel Kohlmeyer [email protected] đã viết:
Dear LAMMPS users,
for your specific setup, wouldn’t it be simpler to use compute/reduce
