Bug in Compute temp/chunk
Dear Developers,
I believe there is a bug in the remove_bias() and restore_bias() functions in ComputeTempChunk. This issue will cause a seg fault when using a temp/chunk with keyword “com yes” as the temperature compute in fix nvt. I think it’s just an off by one error:
L692 and L729 of compute_temp_chunk.cpp (May 14 2016 version):
int index = cchunk->ichunk[i];
should be changed to:
int index = cchunk->ichunk[i]-1;
The same correction may also be needed for remove_bias_all() and restore_bias_all() on L714 and L752. Also, I’m a little confused about whether these two functions are correct. As far as I can tell, vbias is never set in temp/chunk. I may be mistaken but I think L716, for example, should be changed to:
v[i][0] -= vcmall[index][0];
-David
hi david,
thanks a lot for the report. for future reference, i have filed it as
issue #74 in the LAMMPS project issue tracker on github:
https://github.com/lammps/lammps/issues/74
i think you are right with the off-by-one, but i will take a closer
look and also check out the other issues.
please stay tuned,
hi again,
it looks like all the issues you list need to be addressed, and there
is also a potential division by zero problem for empty chunks.
the following patch should correct it.
diff --git a/src/compute_temp_chunk.cpp b/src/compute_temp_chunk.cpp
index 5a58535..87d6e11 100644
--- a/src/compute_temp_chunk.cpp
+++ b/src/compute_temp_chunk.cpp
@@ -472,9 +472,13 @@ void ComputeTempChunk::vcm_compute()
   MPI_Allreduce(massproc,masstotal,nchunk,MPI_DOUBLE,MPI_SUM,world);
   for (i = 0; i < nchunk; i++) {
- vcmall[i][0] /= masstotal[i];
- vcmall[i][1] /= masstotal[i];
- vcmall[i][2] /= masstotal[i];
+ if (masstotal[i] > 0.0) {
+ vcmall[i][0] /= masstotal[i];
+ vcmall[i][1] /= masstotal[i];
+ vcmall[i][2] /= masstotal[i];
+ } else {
+ vcmall[i][0] = vcmall[i][1] = vcmall[i][2] = 0.0;
@@ -689,7 +693,7 @@ void ComputeTempChunk::internal(int icol)
void ComputeTempChunk::remove_bias(int i, double *v)
- int index = cchunk->ichunk[i];
+ int index = cchunk->ichunk[i]-1;
   if (index < 0) return;
   v[0] -= vcmall[index][0];
   v[1] -= vcmall[index][1];
@@ -711,11 +715,11 @@ void ComputeTempChunk::remove_bias_all()
   for (int i = 0; i < nlocal; i++)
     if (mask[i] & groupbit) {
- index = ichunk[i];
+ index = ichunk[i]-1;
       if (index < 0) continue;
- v[i][0] -= vbias[0];
- v[i][1] -= vbias[1];
- v[i][2] -= vbias[2];
+ v[i][0] -= vcmall[index][0];
+ v[i][1] -= vcmall[index][1];
+ v[i][2] -= vcmall[index][2];
@@ -726,7 +730,7 @@ void ComputeTempChunk::remove_bias_all()
void ComputeTempChunk::restore_bias(int i, double *v)
   v[0] += vcmall[index][0];
   v[1] += vcmall[index][1];
@@ -749,11 +753,11 @@ void ComputeTempChunk::restore_bias_all()
- v[i][0] += vbias[0];
- v[i][1] += vbias[1];
- v[i][2] += vbias[2];
+ v[i][0] += vcmall[index][0];
+ v[i][1] += vcmall[index][1];
+ v[i][2] += vcmall[index][2];
Looks good, thank you Axel.
-David
thanks, should be in a patch for LAMMPS soon.
