The C++ compiler is interpreting the following code in an unintended
fashion (library.cpp, lines 501-511):
if (count == 1)
for (i = 0; i < natoms; i++)
if ((m = lmp->atom->map(i+1)) >= 0)
vector[m] = dptr[i];
else
if ((m = lmp->atom->map(i+1)) >= 0) {
offset = count*i;
for (j = 0; j < count; j++)
array[m][j] = dptr[offset++];
This can be fixed by adding braces around the outer if/else statements,
as is done for the type != 0 case below it.
Karl D. Hammond
University of Tennessee, Knoxville
"You can never know everything, and part of what you know is always
wrong. A portion of wisdom lies in knowing that. A portion of courage
lies in going on anyway."
"Nothing ever goes as you expect. Expect nothing, and you will not be
surprised."
