I think I found a bug in the partition command, which is reproduced by the
following short C program (which links to LAMMPS as a library):
/* START */
#include "library.h"
int main (int argc, char **argv) {
void *lmp = NULL;
lammps_open_no_mpi (argc, argv, &lmp);
lammps_command (lmp, "partition yes 1 print 'Hello'");
lammps_close (lmp);
return 0;
} /* END */
It gets more interesting if you remove the single quotes. *smile*
The culprit is lines 783 of input.cpp:
strcpy(copy,line); // line 782
copy[strlen(copy)-1] = '\0';
char *ptr = strtok(copy," \t\n\r\f");
Line 783 assumes that the last character in "line" is \n, which is not the
case in the example above (though it would be if I'd read the command from
a file the way input->file does it).
I think simply deleting that line is a fix, since the strtok command will
remove the \n anyway if it's present.
An alternative is to do something like
if ( copy[strlen(copy)-1] == '\n' ) copy[strlen(copy)-1] = '\0';
Karl D. Hammond
University of Tennessee, Knoxville
[email protected]...
"You can never know everything, and part of what you know is always
wrong. A portion of wisdom lies in knowing that. A portion of courage
lies in going on anyway."
"Nothing ever goes as you expect. Expect nothing, and you will not be
surprised."
