Bug report about compiling the USER-MISC package
Dear LAMMPS developers,
When I compile the USER-MISC package in the latest stable version of LAMMPS (lammps-10Aug15), encounters the following error:
​what OS/Hardware/Compiler are you using​?
this code compiles without a problem using GCC.
i am frequently building binary RPMs and windows installers with various
settings and Linux versions as well as running continuous integration
testing and this never failed because of the error message below.
../pair_list.cpp(88): error: expected a ";"
     const dbl3_t * _noalias const x = (dbl3_t *) atom->x[0];
../pair_list.cpp(89): error: "restrict" has already been declared in the
current scope
     dbl3_t * _noalias const f = (dbl3_t *) atom->f[0];
../pair_list.cpp(89): error: expected a ";"
../pair_list.cpp(114): error: identifier "x" is undefined
       const double dx = x[i].x - x[j].x;
../pair_list.cpp(160): error: identifier "f" is undefined
         f[i].x += dx*fpair;
../pair_list.cpp(166): error: identifier "f" is undefined
         f[j].x -= dx*fpair;
compilation aborted for ../pair_list.cpp (code 2)
make[1]: *** [pair_list.o] Error 2
make: *** [mpi] Error 2
And then I find that the error is due to the following codes in
pair_list.cpp:
And it's interesting that it can be compiled successfully using the
pair_list.cpp with also these two lines.
After reading the pair_list.cpp carefully, I realize that:
(1) For the old version of LAMMPS, there exists the following definition:
#if defined(__GNUC__)
#define _noalias __restrict
#else
#define _noalias
#endif
which is related to _noalias.
(2) But for the latest version, no the above definition, so the
compiling error occurs.
​that macro has been moved to lmptype.h​
(3) And then I change the two lines in the pair_list.cpp to be
   const dbl3_t * const x = (dbl3_t *) atom->x[0];
   dbl3_t * const f = (dbl3_t *) atom->f[0];
Then the compiling error disappears !
But I'm not sure if we should delete the word "_noalias", and please fix
this bug for compiling USER-MISC.
​it is more likely a bug in the compiler you are using.
axel.​
Dear axel.
OS: Linux
Hardware: The HPC-Cluster consists of Intel Xeon-based 8- to 128-way SMP nodes. (Read from HPC User's Guide </pages/viewpage.action?pageId=3473705>)
Compiler: Intel
mpicxx -g -O3 -DLAMMPS_GZIP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1 -M ../write_restart.cpp > write_restart.d
It can works if I delete the word "_noalias", but will it influence the simulations results?
If it has an effect on the simulation results, I will change the compiler to be gcc, as you suggested.
Thanks.
Xiaoliang
Dear axel.
OS: Linux
<http:///pages/viewpage.action?pageId=3473705>)
Compiler: Intel
​no. it will only affect how well the compiler can optimize the affected
subroutine(s). any impact on simulations would be equivalent to turning
other optimizations on or off. ​the purpose of this macros is to tell the
compiler that pointer variables point to address space that no other
pointers will be pointing to. by default a C/C++ compiler has to assume
they do and thus cannot do particular optimizations.
