Hello
I found a bug in lammps-30Oct14 which is set off when I use
"create_atoms", followed by "write_data". I have attached an example
script and molecule template file which causes the error:
ERROR: Atom count is inconsistent, cannot write data file
(../write_data.cpp:150)
If it helps, to my eyes, it appears that the evil magic occurs
near this line: comm_brick.cpp:837
(which is invoked by write_data.cpp:118)
I say this because at this moment, the numbers in atom->x[1][0],
x[1][1], and x[1][2] no longer look correct to me after this point,
but I could be wrong about this.
Cheers!
Andrew
(Just to be clear, I have my own customized version of
create_atoms.cpp to submit. But I am not using it for this bug
report. I am using the original version from October30th.)
in.create.molecule (540 Bytes)
molecule.dimer (153 Bytes)
