For atomstyle template (polymer) with Fene bonds I get different outcomes for newton on and off. It crashes for newton off. Possible bug?
Thanks and regards,
Thanks and regards,
Crash output? LAMMPS version? OS? Compiler and settings? example script?
what about #3 and #9 of http://lammps.sandia.gov/guidelines.html ?
Apologies for witholding details.
I used LAMMPS: Jul 30, 2016 version (serial) on Ubuntu compiled with debug setting (-g -O). I am also attaching all required files for run herewith (tar.gz file).
To summarize the issue,
With “newton off” it crashed with following error where as with “newton on” it didn’t
tail -5 newton_off:
WARNING: FENE bond too long: 702 164 165 1.54581 (…/bond_fene.cpp:91)
WARNING: FENE bond too long: 703 61 62 2.24083 (…/bond_fene.cpp:91)
WARNING: FENE bond too long: 703 106 107 2.15495 (…/bond_fene.cpp:91)
WARNING: FENE bond too long: 703 108 109 3.00592 (…/bond_fene.cpp:91)
ERROR on proc 0: Bad FENE bond (…/bond_fene.cpp:92)
Input script used:
#temperature in reduced units
variable temp equal 3.0
dimension 2
units lj
molecule poly1 poly1.molecule
atom_style template poly1
#neighbor settings
neighbor 2.0 bin
newton off
#add additional particles to box
region box block -32 32 -32 32 -2.0 2.0
region myCylinder cylinder z 0 0 30 -2.0 2.0
create_box 1 box bond/types 1 angle/types 1 extra/bond/per/atom 2 extra/angle/per/atom 1 extra/special/per/atom 6
read_data poly.input add merge
mass * 1
group mobile type 1
pair_style lj/cut 1.12246204830937
pair_coeff * * 1.0 1.0 1.12246204830937
pair_modify shift yes
#FENE type bond
bond_style fene
bond_coeff 1 30.0 1.5 1.0 1.0
#bond_style harmonic
#bond_coeff 1 40.0 0.96
special_bonds fene
angle_style harmonic
angle_coeff 1 100 180
#remove overlap between polymer and obstacles
minimize 1e-10 1e-10 100 100
reset_timestep 0
Thanks so much,
Abhijeet
fene_newton_crash.tar.gz (66 KB)
Perhaps it could be generic issue with template style.
If I understand correctly, for newton off case number of bonds associated with each polymer bead (except the end ones) should be equal to 2. However, I notice it to be registered as 1.
Update.
I think I found out what’s going on.
I set newton command before command molecule and it worked without issues.
Abhijeet
