Hello
I stumbled into a small bug in fix_property_atom.cpp. A segfault
occurs if the user asks LAMMPS to read a data file containing the
wrong number of atoms in the custom data section. (See attached
example: system.data, run.in. I also attached a new
fix_property_atom.cpp based on lammps-15Dec15. Diff below)
Happy holidays
Andrew
225,226c225
< bool read_failure = (values[0] == NULL);
< for (j = 1; j < nwords; j++) {
fix_property_atom.cpp (18.4 KB)
run.in (959 Bytes)
system.data (886 Bytes)
Hello
hi andrew,
i've integrated your proposed change with some small modifications into
LAMMPS-ICMS.
due to the "optimistic" nature of the data file format, reading incorrectly
formatted or inconsistent data files can often lead to such segfaults and
not all of them are as easily caught as the one you ran across. i
personally consider this a design flaw of the data file format (if it had
properly tagged, self-descriptive sections, with more strict formatting
requirements, this could be avoided and the files more easily validated and
parsed, especially by external tools).
unfortunately, i have not yet found an argument to convince steve, that
this is worth the effort (and breaking backward compatibility).
