I have tried many different options in my makefile but I am still getting the following error message while building the lammps mkl:
-lpthread -lmpi /opt/intel/mkl/lib/intel64/libfftw2xf_intel.a -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lstdc++ -o …/lmp_mkl
ld: cannot find -limf
make[1]: *** […/lmp_mkl] Error 1
make[1]: Leaving directory `/root/lammps-12Apr12/src/Obj_mkl’
make: *** [mkl] Error 2
[root@…36…3390…:~/lammps-12Apr12/src]# vi ./MAKE/Makefile.mkl
and my make file is :
SHELL = /bin/sh
compiler/linker settings
specify flags and libraries needed for your compiler
CC = icc
CCFLAGS = -O2 -fno-alias -ip -unroll0
DEPFLAGS = -M
LINK = icc
LINKFLAGS = -O -L/opt/intel/mkl/lib/intel64
#LIB = -lstdc++ -lpthread
LIB = -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lstdc++
ARCHIVE = ar
ARFLAGS = -rc
SIZE = size
LAMMPS-specific settings
specify settings for LAMMPS features you will use
if you change any -D setting, do full re-compile after “make clean”
LAMMPS ifdef settings, OPTIONAL
see possible settings in doc/Section_start.html#2_2 (step 4)
LMP_INC = -DLAMMPS_GZIP
MPI library, REQUIRED
see discussion in doc/Section_start.html#2_2 (step 5)
can point to dummy MPI library in src/STUBS as in Makefile.serial
INC = path for mpi.h, MPI compiler settings
PATH = path for MPI library
LIB = name of MPI library
MPI_INC = -l/opt/intel/impi/4.0.3/intel64/include -DMPICH_IGNORE_CXX_SEEK
MPI_PATH = -L/opt/intel/impi/4.0.3/intel64/lib
MPI_LIB = -lpthread -lmpi
#MPI_INC = -DMPICH_IGNORE_CXX_SEEK
#MPI_PATH =
#MPI_LIB = -mt_mpi
FFT library, OPTIONAL
see discussion in doc/Section_start.html#2_2 (step 6)
can be left blank to use provided KISS FFT library
INC = -DFFT setting, e.g. -DFFT_FFTW, FFT compiler settings
PATH = path for FFT library
LIB = name of FFT library
FFT_INC = -DFFT_FFTW -I/opt/intel/mkl/include/fftw
FFT_PATH =
FFT_LIB = /opt/intel/mkl/lib/intel64/libfftw2xf_intel.a
Maybe I am missing something in the makefile, could you please tell me if you see something wrong in this configuration?
Thanks a lot & B.Regards,
Dogan
