I am using the 10Aug15 version of lammps and am having trouble building on mac 10.6.8 as a shared library with the meam package.
When I try to build I get this error:
Undefined symbols for architecture x86_64:
“__intel_fast_memcpy”, referenced from:
compute_pair_meam in libmeam.a(meam_setup_done.o)
interpolate_meam in libmeam.a(meam_setup_done.o)
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
make[1]: *** [shlib] Error 1
make: *** [mac] Error 2
Here is the Makefile.mac i am using:
mac = Apple PowerBook G4 laptop, c++, no MPI, FFTW 2.1.5
SHELL = /bin/sh
compiler/linker settings
specify flags and libraries needed for your compiler
CC = g++
CCFLAGS = -O
SHFLAGS = -fPIC
DEPFLAGS = -M
LINK = ifort
LINKFLAGS = -O
LIB = -lmeam
SIZE = size
ARCHIVE = ar
ARFLAGS = -rc
SHLIBFLAGS = -shared
LAMMPS-specific settings, all OPTIONAL
specify settings for LAMMPS features you will use
if you change any -D setting, do full re-compile after “make clean”
LAMMPS ifdef settings
see possible settings in Section 2.2 (step 4) of manual
LMP_INC = -DLAMMPS_GZIP
MPI library
see discussion in Section 2.2 (step 5) of manual
MPI wrapper compiler/linker can provide this info
can point to dummy MPI library in src/STUBS as in Makefile.serial
use -D MPICH and OMPI settings in INC to avoid C++ lib conflicts
INC = path for mpi.h, MPI compiler settings
PATH = path for MPI library
LIB = name of MPI library
MPI_INC = -I…/STUBS
MPI_PATH = -L…/STUBS
MPI_LIB = -lmpi_stubs
FFT library
see discussion in Section 2.2 (step 6) of manaul
can be left blank to use provided KISS FFT library
INC = -DFFT setting, e.g. -DFFT_FFTW, FFT compiler settings
PATH = path for FFT library
LIB = name of FFT library
FFT_INC = -DFFT_FFTW
FFT_PATH =
FFT_LIB = -lfftw
JPEG and/or PNG library
see discussion in Section 2.2 (step 7) of manual
only needed if -DLAMMPS_JPEG or -DLAMMPS_PNG listed with LMP_INC
INC = path(s) for jpeglib.h and/or png.h
PATH = path(s) for JPEG library and/or PNG library
LIB = name(s) of JPEG library and/or PNG library
JPG_INC =
JPG_PATH =
JPG_LIB =
I would appreciate any help with this
Jacob Holesinger
