I am trying to build lammps with the following,
Lammps version 12Dec2018
CUDA_ARCH = -arch=sm_60
using Portland Group Compilers
the buiilding of the GPU library is fine, but while doing “make gpu” it is throwing errors which i have no idea. Please suggest me what I am missing. The errors are as follows,
compute_pair_local.o: In function .st4433': compute_pair_local.cpp:(.data+0x20): undefined reference to
.LB4104’
compute_pair_local.cpp:(.data+0x28): undefined reference to .LB4105' compute_pair_local.cpp:(.data+0x30): undefined reference to
.LB4106’
compute_pair_local.cpp:(.data+0x38): undefined reference to .LB4107' compute_pair_local.cpp:(.data+0x40): undefined reference to
.LB4108’
compute_pair_local.cpp:(.data+0x48): undefined reference to .LB4109' compute_pair_local.cpp:(.data+0x50): undefined reference to
.LB4110’
compute_rigid_local.o: In function .st3984': compute_rigid_local.cpp:(.data+0x20): undefined reference to
.LB3828’
compute_rigid_local.cpp:(.data+0x28): undefined reference to .LB3829' compute_rigid_local.cpp:(.data+0x30): undefined reference to
.LB3830’
compute_rigid_local.cpp:(.data+0x38): undefined reference to .LB3831' compute_rigid_local.cpp:(.data+0x40): undefined reference to
.LB3832’
compute_rigid_local.cpp:(.data+0x48): undefined reference to .LB3833' compute_rigid_local.cpp:(.data+0x50): undefined reference to
.LB3834’
compute_rigid_local.cpp:(.data+0x58): undefined reference to .LB3835' compute_rigid_local.cpp:(.data+0x60): undefined reference to
.LB3836’
compute_rigid_local.cpp:(.data+0x68): undefined reference to .LB3837' compute_rigid_local.cpp:(.data+0x70): undefined reference to
.LB3838’
compute_rigid_local.cpp:(.data+0x78): undefined reference to .LB3839' compute_rigid_local.cpp:(.data+0x80): undefined reference to
.LB3840’
compute_rigid_local.cpp:(.data+0x88): undefined reference to .LB3841' compute_rigid_local.cpp:(.data+0x90): undefined reference to
.LB3842’
compute_rigid_local.cpp:(.data+0x98): undefined reference to .LB3843' compute_rigid_local.cpp:(.data+0xa0): undefined reference to
.LB3844’
compute_rigid_local.cpp:(.data+0xa8): undefined reference to .LB3845' compute_rigid_local.cpp:(.data+0xb0): undefined reference to
.LB3846’
compute_rigid_local.cpp:(.data+0xb8): undefined reference to .LB3847' compute_rigid_local.cpp:(.data+0xc0): undefined reference to
.LB3848’
compute_rigid_local.cpp:(.data+0xc8): undefined reference to .LB3849' compute_rigid_local.cpp:(.data+0xd0): undefined reference to
.LB3850’
compute_rigid_local.cpp:(.data+0xd8): undefined reference to .LB3851' compute_rigid_local.cpp:(.data+0xe0): undefined reference to
.LB3852’
compute_rigid_local.cpp:(.data+0xe8): undefined reference to .LB3853' compute_rigid_local.cpp:(.data+0xf0): undefined reference to
.LB3854’
compute_rigid_local.cpp:(.data+0xf8): undefined reference to .LB3855' compute_rigid_local.cpp:(.data+0x100): undefined reference to
.LB3856’
compute_rigid_local.cpp:(.data+0x108): undefined reference to .LB3857' compute_rigid_local.cpp:(.data+0x110): undefined reference to
.LB3858’
compute_rigid_local.cpp:(.data+0x118): undefined reference to .LB3859' compute_rigid_local.cpp:(.data+0x120): undefined reference to
.LB3860’
compute_rigid_local.cpp:(.data+0x128): undefined reference to .LB3861' compute_rigid_local.o: In function
.st5135’:
compute_rigid_local.cpp:(.data+0x140): undefined reference to .LB4935' compute_rigid_local.cpp:(.data+0x148): undefined reference to
.LB4936’
compute_rigid_local.cpp:(.data+0x150): undefined reference to .LB4937' compute_rigid_local.cpp:(.data+0x158): undefined reference to
.LB4938’
compute_rigid_local.cpp:(.data+0x160): undefined reference to .LB4939' compute_rigid_local.cpp:(.data+0x168): undefined reference to
.LB4940’
compute_rigid_local.cpp:(.data+0x170): undefined reference to .LB4941' compute_rigid_local.cpp:(.data+0x178): undefined reference to
.LB4942’
compute_rigid_local.cpp:(.data+0x180): undefined reference to .LB4943' compute_rigid_local.cpp:(.data+0x188): undefined reference to
.LB4944’
compute_rigid_local.cpp:(.data+0x190): undefined reference to .LB4945' compute_rigid_local.cpp:(.data+0x198): undefined reference to
.LB4946’
compute_rigid_local.cpp:(.data+0x1a0): undefined reference to .LB4947' compute_rigid_local.cpp:(.data+0x1a8): undefined reference to
.LB4948’
compute_rigid_local.cpp:(.data+0x1b0): undefined reference to .LB4949' compute_rigid_local.cpp:(.data+0x1b8): undefined reference to
.LB4950’
compute_rigid_local.cpp:(.data+0x1c0): undefined reference to .LB4951' compute_rigid_local.cpp:(.data+0x1c8): undefined reference to
.LB4952’
compute_rigid_local.cpp:(.data+0x1d0): undefined reference to .LB4953' compute_rigid_local.cpp:(.data+0x1d8): undefined reference to
.LB4954’
compute_rigid_local.cpp:(.data+0x1e0): undefined reference to .LB4955' compute_rigid_local.cpp:(.data+0x1e8): undefined reference to
.LB4956’
compute_rigid_local.cpp:(.data+0x1f0): undefined reference to .LB4957' compute_rigid_local.cpp:(.data+0x1f8): undefined reference to
.LB4958’
compute_rigid_local.cpp:(.data+0x200): undefined reference to .LB4959' compute_rigid_local.cpp:(.data+0x208): undefined reference to
.LB4960’
compute_rigid_local.cpp:(.data+0x210): undefined reference to .LB4961' compute_rigid_local.cpp:(.data+0x218): undefined reference to
.LB4962’
compute_rigid_local.cpp:(.data+0x220): undefined reference to .LB4963' compute_rigid_local.cpp:(.data+0x228): undefined reference to
.LB4964’
compute_rigid_local.cpp:(.data+0x230): undefined reference to .LB4965' compute_rigid_local.cpp:(.data+0x238): undefined reference to
.LB4966’
compute_rigid_local.cpp:(.data+0x240): undefined reference to .LB4967' compute_rigid_local.cpp:(.data+0x248): undefined reference to
.LB4968’
compute_bond_local.o: In function .st5216': compute_bond_local.cpp:(.data+0x20): undefined reference to
.LB4812’
compute_bond_local.cpp:(.data+0x28): undefined reference to .LB4813' compute_bond_local.cpp:(.data+0x30): undefined reference to
.LB4814’
compute_bond_local.cpp:(.data+0x38): undefined reference to .LB4815' compute_bond_local.cpp:(.data+0x40): undefined reference to
.LB4816’
compute_bond_local.cpp:(.data+0x48): undefined reference to .LB4817' compute_bond_local.cpp:(.data+0x50): undefined reference to
.LB4818’
compute_bond_local.cpp:(.data+0x58): undefined reference to .LB4819' compute_bond_local.cpp:(.data+0x60): undefined reference to
.LB4820’
compute_bond_local.o: In function .st6779': compute_bond_local.cpp:(.data+0x80): undefined reference to
.LB6194’
compute_bond_local.cpp:(.data+0x88): undefined reference to .LB6195' compute_bond_local.cpp:(.data+0x90): undefined reference to
.LB6196’
compute_bond_local.cpp:(.data+0x98): undefined reference to .LB6197' compute_bond_local.cpp:(.data+0xa0): undefined reference to
.LB6198’
compute_bond_local.cpp:(.data+0xa8): undefined reference to .LB6199' compute_bond_local.cpp:(.data+0xb0): undefined reference to
.LB6200’
compute_bond_local.cpp:(.data+0xb8): undefined reference to .LB6201' compute_bond_local.cpp:(.data+0xc0): undefined reference to
.LB6202’
Makefile:89: recipe for target ‘…/lmp_gpu’ failed
make[1]: *** […/lmp_gpu] Error 2
make[1]: Leaving directory ‘/home/softMatter/134026005/lammps-12Dec18/src/Obj_gpu’
Makefile:176: recipe for target ‘gpu’ failed
make: *** [gpu] Error 2
Thanks ®ards,
Umashankar
