I’m interested to try out the LAMMPS (29Aug2014) with Kokkos functionality targeting Xeon Phi. Does anyone have experience with appropriate Makefile settings to build LAMMPS in this case? For example, in the instructions here: http://lammps.sandia.gov/doc/Section_accelerate.html#acc_8 it states:
Intel Xeon Phi:
cd lammps/src
make yes-kokkos
make g++ OMP=yes MIC=yes
which if I understand correctly would use the Makefile included in the source distribution at src/MAKE/ Makefile.g++?
I’ve been trying to make LAMMPS with Kokkos for use on Xeon Phi with variations on the src/MAKE/Makefile.intel (using Intel Compiler 14.0.3, Intel MPI 5.0.1.035, Intel MPSS 3.3). While I am getting a successful build, when I try to run for example the colloid example included with LAMMPS:
mpirun -hosts rx350-1-mic0 -n 4 -env LD_LIBRARY_PATH $MIC_LD_LIBRARY_PATH …/src/lmp_intel_intelmpi -k on t 1 -sf kk < in.colloid > colloid_test.log 2>&1
(and I’ve tried different parameters for –n and –k on t, e.g 2/1 2/2 etc), I always get the following crash at runtime immediately after the LAMMPS processes start on the Xeon Phi
$ cat colloid_test.log
LAMMPS (29 Aug 2014)
KOKKOS mode is enabled (…/lammps.cpp:469)
*** glibc detected *** …/src/lmp_intel_intelmpi: realloc(): invalid old size: 0x0000000001b0fc00 ***
*** glibc detected *** …/src/lmp_intel_intelmpi: realloc(): invalid old size: 0x0000000001f4c980 ***
*** glibc detected *** …/src/lmp_intel_intelmpi: realloc(): invalid old size: 0x0000000002fff980 ***
*** glibc detected *** …/src/lmp_intel_intelmpi: realloc(): invalid old size: 0x00000000021ab980 ***
Some of the compiler options in the standard src/MAKE/Makefile.intel are:
CC = mpiicpc -openmp -DLAMMPS_MEMALIGN=64 -no-offload
CCFLAGS = -O3 -xHost -fno-alias -ansi-alias -restrict -override-limits
SHFLAGS = -fPIC
DEPFLAGS = -M
LINK = mpiicpc -openmp
LINKFLAGS = -O3 -xHost
-xHost obviously is not compatible with –mmic, what about the other options here? Or is the problem possibly elsewhere?
Best Regards,
Paul.
