Hello Dear lammps users
I want to define bulk free energy per atom for the icosahedral copper cluster.
the code i used is as follow:
clear
atom_style atomic
atom_modify map array
create atom
lattice fcc 3.61
read_data data.00309_ico
mass 1 63.546
#define interatomic potential
pair_style eam
pair_coeff * * cu_u3.eam
neighbor 2 bin
neigh_modify delay 10 check yes
#compute
compute eng all pe/atom
compute eatoms all reduce sum c_eng
run minimization
reset_timestep 0
fix 1 all box/relax iso 0.0 vmax 0.1
thermo 10
thermo_style custom step pe lx ly lz press pxx pyy pzz c_eatoms
min_style cg
minimize 0 0 500000 1000000
dump 1 all xyz 100 bulk.xyz
variable natoms equal “count(all)”
variable teng equal “c_eatoms”
variable length equal “lx”
variable ecoh equal “v_teng/v_natoms”
print “Total energy (eV) = ${teng};”
print “Number of atoms = ${natoms};”
print “Lattice constant (Angstoms) = ${length};”
print “Cohesive energy (eV) = ${ecoh};”
the problem is for different number of atoms in cluster,this code gives me different bulk energy per atom.
but i think it should be the same for different size of cluster.
what is the problem?
data.00309_ico (9.78 KB)
cluster.
the problem is in your thinking. you are not computing the "bulk
energy"; you are computing the "total energy", i.e. you sum over atoms
at the surface as well as atoms below the surface and atoms deep
inside the cluster. only those buried deep inside will be "bulk-like",
and only if the cluster is large enough so that its environment deep
inside is, in fact, bulk-like. atoms close to the surface have
different interaction strength.
Dear Axel
I am calculating surface energy of this cluster with this formula:
where Ep-cluster is the potential energy of the cluster, Ep-bulk is
the potential energy of a bulk system containing the same
number of atoms, and A -cluster is the total cluster surface area.
you mean i calculated E-bulk in a wrong way?
so what should i do?
cluster.
the problem is in your thinking. you are not computing the “bulk
energy”; you are computing the “total energy”, i.e. you sum over atoms
inside the cluster. only those buried deep inside will be “bulk-like”,
Dear Axel
[image: Inline image]
yes.
do it correctly, i.e. do exactly as the formula you are quoting says.
while it is easy to compute the (potential) energy per atom of a bulk system and thus get your E_P,bulk and also to compute the (potential) energy of your cluster, there is the open question, how you compute the surface area? the formula you quote is easy to apply for slab geometries, but to triangulate the surface of a cluster, you need to make assumptions on the “size” of an atom, which is ill-defined.
i am also wondering how this all relates to the script you were quoting.
Dear axel
I used the q-hull software to calculate surface area for different size of cluster with different number of atoms to define size dependent surface energy.
http://www.qhull.org/
this surface area can be used directly in the formula.
After defining surface energy i can have a curve for surface energy vs number of atoms and see the results.
Best regards
Malihe Razavi
Dear axel
energy.
<http://www.qhull.org/>
but that doesn't make the cluster surface a well defined entity. you just
are using whatever heuristics are employed in this software. if i remember
correctly, the qhull code simply takes the positions of atoms without
considering their radii, which means that you will underestimate the
surface and systematically more so, the smaller the clusters are. and like
i mentioned before, this radius is not well defined.
Dear axel
Your advice was quite to the point ,that the code i wrote in my previous email doesn’t calculate bulk energy
because of the energy of atom on the surface.but i used periodic boundary condition.
when we use this boundary condition it gives us bulk property without considering the atoms on the surface.
I will be grateful if you help for this problem.
Thank you very much indeed
Malihe Razavi
Dear axel
but that doesn’t make the cluster surface a well defined entity. you just are using whatever heuristics are employed in this software. if i remember correctly, the qhull code simply takes the positions of atoms without considering their radii, which means that you will underestimate the surface and systematically more so, the smaller the clusters are. and like i mentioned before, this radius is not well defined.
Dear axel
email doesn't calculate bulk energy
condition.
what has one to do with the other?
i don't understand what you are asking for here. post a specific
(working) input deck and ask a specific question, and somebody might be
able to give advice.
