I am trying to compute matminer feature using
cf.ElementProperty.from_preset(“matminer”)
It work fine for other features, but for ‘PymatgenData mean bulk_modulus’ for composition such as Al0.25NbTaTiZr (writes NaN), but it works for Al0.25NbTaTiV
I figured from /utils/data_files/magpie_elementdata/BulkModulus.table that the data for Zr is missing. I found out the value from literature and filled the “Missing” Zr value.
It still does not work.
Is there a way to fix it?
Debasis
Hello Debasis,
The error here stems from the “matminer” present of ElementProperty using data from pymatgen, and not the tables in the “magpie_elementdata” folder.
You can edit the Pymatgen data by changing the value in Pymatgen before computing features. See code example below.
Logan
from pymatgen import Element, Composition
x = Element(‘Zr’)
x.bulk_modulus
x = Element(‘Fe’)
x.bulk_modulus
170.0
x = Element(‘Zr’)
from matminer.featurizers.composition import ElementProperty
e = ElementProperty(‘pymatgen’, [‘bulk_modulus’], [‘mean’])
e.featurize(Composition(‘Zr’))
[nan]
x.bulk_modulus = 10
[10.0]
Sent: Wednesday, July 17, 2019 10:28 AM
To: matminer
Subject: Bulk modulus missing data
Debasis
You received this message because you are subscribed to the Google Groups “matminer” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To view this discussion on the web visit https://groups.google.com/d/msgid/matminer/63cea14b-d8cb-4086-b829-e8b44b3f900b%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Hi Logan,
Thanks for the tips.
Is there a way I can directly edit that data file in pymatgen instead of assigning value by scripting? Where should I look for the pymatgen bulk modulus data file that I can edit and save?
Debasis
Debasis
Yes, you can edit the “periodic_table.json” file associated with Pymatgen.
See: https://github.com/materialsproject/pymatgen/blob/master/pymatgen/core/periodic_table.json
Logan
Sent: Thursday, July 18, 2019 10:12 AM
To: matminer
Subject: Re: Bulk modulus missing data
Hi Logan,
Debasis
Debasis
To view this discussion on the web visit https://groups.google.com/d/msgid/matminer/80cccacd-8165-4ec7-b043-90ed2e09429f%40googlegroups.com.
