I have been developing a C++ code using the LAMMPS interface. I have recently noticed memory leakage issues and started cleaning the code up (various arrays created with “new double” and then not deleted []…).
I noticed that I am unable to delete [] any array to which I casted property/atom via lammps_extract_compute.
I have downloaded the latest version of LAMMPS (7Aug19) and edited the example/COUPLE/simple/simple.cpp to reproduce the error. I have copied the edited main below, highlighting between ************ any lines that I have added. Everything works fine and I can read and print atom IDs using the compute, but when I get to
delete [] aID
at the very bottom, the code crashes with Abort trap: 6 (signal 6)
I am concerned because I am using this approach extensively in my code, creating such aIDs (and others for radii, type, energy, stress per atom) in a function that is called in a loop for thousands of times. If I do not delete them, I am afraid this could cause memory leakage. Notice that any other array that I create and manipulate (as long as not casting from lammps) can be deleted without any problem, as expected.
Last note, unrelated but since I’m here… If you can suggest a better way to evaluate a property/atom compute rather than my approach of creating, using, and then overwriting a temporary dump every time, I’d be very interested (let me know if I should open a separate thread for this).
Thank you,
Enrico
int main(int narg, char **arg)
// setup MPI and various communicators
// driver runs on all procs in MPI_COMM_WORLD
// comm_lammps only has 1st P procs (could be all or any subset)
MPI_Init(&narg,&arg);
if (narg != 3) {
printf(“Syntax: simpleCC P in.lammps\n”);
exit(1);
int me,nprocs;
MPI_Comm_rank(MPI_COMM_WORLD,&me);
MPI_Comm_size(MPI_COMM_WORLD,&nprocs);
int nprocs_lammps = atoi(arg[1]);
if (nprocs_lammps > nprocs) {
if (me == 0)
printf(“ERROR: LAMMPS cannot use more procs than available\n”);
MPI_Abort(MPI_COMM_WORLD,1);
int lammps;
if (me < nprocs_lammps) lammps = 1;
else lammps = MPI_UNDEFINED;
MPI_Comm comm_lammps;
MPI_Comm_split(MPI_COMM_WORLD,lammps,0,&comm_lammps);
// open LAMMPS input script
FILE *fp;
if (me == 0) {
fp = fopen(arg[2],“r”);
if (fp == NULL) {
printf(“ERROR: Could not open LAMMPS input script\n”);
// run the input script thru LAMMPS one line at a time until end-of-file
// driver proc 0 reads a line, Bcasts it to all procs
// (could just send it to proc 0 of comm_lammps and let it Bcast)
// all LAMMPS procs call input->one() on the line
LAMMPS *lmp = NULL;
if (lammps == 1) lmp = new LAMMPS(0,NULL,comm_lammps);
int n;
char line[1024];
while (1) {
if (me == 0) {
if (fgets(line,1024,fp) == NULL) n = 0;
else n = strlen(line) + 1;
if (n == 0) fclose(fp);
MPI_Bcast(&n,1,MPI_INT,0,MPI_COMM_WORLD);
if (n == 0) break;
MPI_Bcast(line,n,MPI_CHAR,0,MPI_COMM_WORLD);
if (lammps == 1) lammps_command(lmp,line);
// run 10 more steps
// get coords from LAMMPS
// change coords of 1st atom
// put coords back into LAMMPS
// run a single step with changed coords
double *x = NULL;
double *v = NULL;
double aID = NULL;
if (lammps == 1) {
lmp->input->one(“run 10”);
int natoms = static_cast (lmp->atom->natoms);
x = new double[3natoms];
v = new double[3natoms];
lammps_gather_atoms(lmp,(char *) “x”,1,3,x);
lammps_gather_atoms(lmp,(char *) “v”,1,3,v);
double epsilon = 0.1;
x[0] += epsilon;
lammps_scatter_atoms(lmp,(char *) “x”,1,3,x);
// these 2 lines are the same
// lammps_command(lmp,“run 1”);
lmp->input->one(“compute tempID all property/atom id”);
lmp->input->one(“dump tdID all custom 1 dump.temp c_tempID”);
aID = new double[natoms]; // array of unsorted IDs
aID = ((double *) lammps_extract_compute(lmp,(char *) “tempID”,1,1));
lmp->input->one(“run 1”);
lmp->input->one(“undump tdID”);
lmp->input->one(“uncompute tempID”);
for (int i=0; i<natoms; i++) printf("%d\n",(int)aID[i]);
// extract force on single atom two different ways
if (lammps == 1) {
double **f = (double **) lammps_extract_atom(lmp,(char *) “f”);
printf(“Force on 1 atom via extract_atom: %g\n”,f[0][0]);
double *fx = (double *)
lammps_extract_variable(lmp,(char *) “fx”,(char *) “all”);
printf(“Force on 1 atom via extract_variable: %g\n”,fx[0]);
// use commands_string() and commands_list() to invoke more commands
char *strtwo = (char *) “run 10\nrun 20”;
if (lammps == 1) lammps_commands_string(lmp,strtwo);
char *cmds[2];
cmds[0] = (char *) “run 10”;
cmds[1] = (char *) “run 20”;
if (lammps == 1) lammps_commands_list(lmp,2,cmds);
// delete all atoms
// create_atoms() to create new ones with old coords, vels
// initial thermo should be same as step 20
int *type = NULL;
if (lammps == 1) {
type = new int[natoms];
for (int i = 0; i < natoms; i++) type[i] = 1;
lmp->input->one(“delete_atoms group all”);
lammps_create_atoms(lmp,natoms,NULL,type,x,v,NULL,0);
delete [] x;
delete [] v;
delete [] type;
delete [] aID;
// close down LAMMPS
delete lmp;
// close down MPI
if (lammps == 1) MPI_Comm_free(&comm_lammps);
MPI_Barrier(MPI_COMM_WORLD);
MPI_Finalize();
