Dear all
I need a little help about applying pressure on C60.
I use displece_atoms command to impose pressure on each atom of C60
fullerene,
i disagree with your wording. what you describe would be called
"compressing a C60 molecule" or "applying strain to a C60 molecule".
pressure is a property of a system and more specifically the force per
area in a defined volume against its boundaries.
second, i don't see much of a meaning in your setup. what is the point
of applying a thermostat to a single molecule? what is the physical
meaning of your calculation?
and in order to integrate equations of motion I use fix nvt command, as
below:
label looplable
displace_atoms all move v_press_x v_press_y v_press_z
#fix forcefinal all addforce v_press_x v_press_y
v_press_z
fix fix1 all nvt temp 300 300 0.01
thermo 5000
thermo_style custom step temp pe v_sigma
run 5000
next Nstep
jump in.CNT looplable
My problems:
due to using fix nvt, C60 start to rotate because there are not any
constraints on C60 atoms.
well, to some degree, it is intrinsic in your model. if your
displacement variables result in only the smallest difference (and
that is likely due to using floating point math, you'll have a net
angular momentum. using a thermostat will usually emphasize it.
also, if you want your C60 to be compressed isotropically *and* have
kinetic energy, where should the kinetic energy go? bond/angle
vibrations will break symmetry, you don't want rotation and if all the
kinetic energy would go into translation, then you can just do a
calculation at 0K (see the recurring discussions of the "flying ice
cube syndrome" on this list).
How can I do to prevent C60 from rotating? as you know, fix rigid ... torque
... command is not proper for this code.
before worrying about this, it is more important to discuss, what you
want to learn from this. i don't see much use in the model you
describe (incompletely), since i cannot imagine any setup, where a
perfectly isotropic strain is imposed on a C60 molecule. anything else
*will* result in (some) rotation. and that kind of rotation will
dissipate only on interactions with other molecules (e.g. a solvent or
other C60s),
and, why "fix addforce" command can not work for this study? (through
following dump file I see that force on each atom is increased but VMD
doesn't show any signs of pressure.
from what you describe fix addforce *does* work, but you may be
underestimating the force on each atom required to (isotropically) and
visibly compress a C60 molecule. this assumes that there are no
mistakes in your input.
please also keep in mind, that a stress/strain curve for a perfectly
isotropic compression of a C60 molecule requires running at 0K and
then - thanks to the high symmetry of C60 - it should be
straightforward to infer it from the force field parameters you are
using.
