Greetings,
I have been experiencing some problems with my nanoindentation. It appears that the indenter is experiencing a great amount of force (seen from the 4[1] 4[2] 4[3] outputs as the indentation is ongoing) even before it contacts my sample: 55x55x55 Angstrom CaF2 sample.
Does anyone have any idea why this would happen?
I have attached the input file and datafile to the email.
Would really appreciate any suggestions
Regards
Janel
CaF2[100]10x10x10.txt (704 KB)
in.CaF2_BUCK2_Nanoindentation.txt (3.48 KB)
Greetings,
how far away? and how do you determine the distance? and under which
condition do you expect contact?
i suspect you are misinterpreting the fix indent documentation.
rather than attaching an input for a huge system, that nobody is
likely to run to check your observations.
it would be much more helpful (to yourself), to set up a small and
fast to run test system (with a smaller indenter) and make some
experiments and validation tests, that determine whether you are
reading the docs right.
LAMMPS ships with an indent example, so that would be a good starting point.
