CALCULATING DENSITY
I am using lammps 9Dec11 to simulate argon in carbon-nanotubes. Please can I know the command to use to get the density across the nanotube lenght? How do I get the display of the density obtained is it automatic?
Regards
Kio Michael
you probably want to use the command "fix ave/spatial"
for details, please have a look at the documentation.
<sarcasm>sure, we are currently working on a write_paper command
that would submit your work automatically to the journal of your
choice</sarcasm>
seriously, please read the documentation. that will tell you
what format the resulting data is in and that in turn should
help you to visualize the results.
cheers,
