I was trying to simulate a Couette flow & oscillatory Couette flow and wanted to know the thermal temperature at different regions(layers along the height of channel).
1) I was using temp/region to do it but I wasnt explicitly sure if it removed the advection velocity while providing the temperature.
2) Also I was assuming the temperature provided by default thermo command and using thermo_style temp would be the same but it comes out to be different.
Would appreciate any comments provided.
Thank you.
BR/Joseph
ps: input script for reference
region fluid block INF INF 2.39 52.5 INF INF units box #<<<<< CHNAGE DIMENSION CORRSPONDING TO PENETRATION DEPTH
region btm_wall block INF INF INF 0.95 INF INF units box
region top_wall block INF INF 53.86 INF INF INF units box #<<<<< CHNAGE DIMENSION CORRSPONDING TO PENETRATION DEPTH
# initial velocities
compute mobile flow temp
velocity flow create 1.10 482748 temp mobile units box
thermo_modify temp mobile
# thermostating
compute mobile_thermo all temp/partial 0 0 1
fix 3 all langevin 1.10 1.10 1.0 699483
fix 1 flow nve
fix 2 lower nve
fix_modify 3 temp mobile_thermo
thermo_modify temp mobile_thermo
# Couette flow
velocity lower set 0.0 0.0 0.0 units box
fix 8 upper move wiggle 10.0 0.0 0.0 20.0 units box #<<<<< CHANGE AMPLITUDE AND TIMEPERIOD
fix 4 boundary setforce 0.0 0.0 0.0
#variable pxy equal pxy
region wall_fluid_1 block INF INF 53.135 53.385 INF INF units box
#group gwall_fluid_1 region wall_fluid_1
#compute temp_tst_1 gwall_fluid_1 temp/com
compute temp_tst_1 all temp/region wall_fluid_1
# Run
timestep 0.002
thermo 1000
#thermo_style custom step temp evdwl ecoul epair ebond edihed eimp eangle emol etotal
#thermo_style custom step temp etotal c_temp_tst_1 c_temp_tst_2 c_temp_tst_3 c_temp_tst_4 c_temp_tst_5 c_temp_tst_6 c_temp_tst_7 c_temp_tst_8 c_temp_tst_9
