Dear all
in order to calculate the flux I used to integrate the velocity profile manually.
Is there a way to directly compute it?
thanks
Fahim
Dear all
thanks
Fahim
There is no context to your question.
Flux of what?
momentum flux
Fahim
I still don't know what you're talking about.
If you are using the fix viscosity command to
do Muller-Plathe, then it tallies the momentum
flux. You measure the velocity gradient by using
fix ave/spatial and the ratio gives you viscosity.
The doc page explains it.
thanks Steve
suppose I want to sum over all atoms velocities in a specific direction (e.g. x-component of velocities, vx), then time averaging on the resultant quantity.
Fahim
