Can anyone suggest me restart2data.py file I am unable to find it in pizza.py tools
hello guys I am trying to use some old restart files with different setting like atom_modify map array that I didn’t used in previous run. so it’s not taking this setting, can anyone suggest me a straight method as I am not being able to find restart2data.py file in the python tools as given in the lammps sourecode.
or can i use a trick like reading the file with same setting and with 0 run and giving write_dump command ? should this work ?
Regards
Irslan Ullah Ashraf
There never was a restart2data.py. Where does it say there should be one?
You can convert restart files to data file with the LAMMPS executable directly.
Thank so much for suggestion, This is like I have solution in my pocket and I am wondering around :smile:
