Can I use the fix msst command with a triclinic cell by LAMMPS?
Dear Steve and everyone: good morning, good afternoon,or good evening!
I was using the fix msst command to load a shock to a triclinic cell. The running was completed normally and the result is quiet reasonable. But restrictions section of this command says ‘this fix can not be used with a triclinic cell’. Would you please tell me it is strictly that it can not be used orjust some error might happen?Will my result make sense?As far as i know, Reed who invented MSST also use MSST at a triclinic cell(J. AM. CHEM. SOC. 2009, 131, 5483–5487 9 5483).
Thank you very much!
Best regard!
Sincerely Wen
Chengdu China
The current implementation of MSST in LAMMPS applies only to
orthorhombic cells and the results would be wrong if it is used for
triclinic cells.
Ray
