Can lammps be coupled as a client to run hyperdynamics ?
Dear LAMMPS users,
I am trying to do hyperdynamics simulation by using the lammps code. I also plan to use the lammps as the client and use the vasp as the server to calculate the forces.
My question is that can the hyper and fix hyper commands be used together with the fix client md command? When the hyperdynamics is performed, for the potential, is the command pair_style only permitted?
Thanks a lot for your help!
Regards,
Hongyang Gu
I can’t think of a good reason why you cannot use hyper, fix hyper, and fix client/md
together. But I’ve never tried it.
