With your fix npt command:
fix NVT all npt temp {T} {T} 100 x 0 0 1000
you only allow it to modify the box size in x direction. how should there be any tilt?
Thanks, I realize it. The correct way is to set “tri 0 0 1000”, then the box angle can change.
On 12/25/2019 21:53,Axel Kohlmeyer<akohlmey@…24…> wrote:
