can the NTLxRyyRz ensemble be applied in LAMMPS
can the Catch0.jpgensemble be applied in the lammps, I search in the manual, this is no information about that in the commond list of fix .
if I have to use the ensemble, waht should I do?
thanks for your advice!
2012-09-09
write code to do it, and add it to LAMMPS.
I had no idea that ensemble existed… =) … something new is learned each day i guess …
Oscar G
I guess you can try using NPT, but only relax y and z, which will achieve the NTL_x. For constant sigma_yy and sigma_zz, I believe you can try with “Pstart Pstop Pdamp” for the y and z keywords.
Ray
