Cannot read restart file after simulation box is defined
I want to perform a set of simulations and their initial state are all defined by a same restart file, so I want to use “loop” to reduce the coding work. However, an error information showed up says that I Cannot read restart file after simulation box is defined. Is there some method to realize my idea?
Follow is part of my code:
variable Epka equal 3
label loop
variable x loop 3
variable dis equal ${x}*15
#-------------------------- READ DATA--------------------------
read_restart restart.cementite-fe.bilayer-10K
next x
jump in.ce-fe.pka loop
realize my idea?
check out the "clear" command.
