Dear Lammps Users,
recently I discovered that the new version of Lammps can be built on the machine with the Amd video card.
I also discovered the a short manual of Andrew Jewett on how to do that. The manual is really great and useful.
Andrew, thank you for that.
http://lammps.sandia.gov/threads/msg36437.html
that helped me a lot and I managed to build the gpu/mpi version of the Lammps.
To do that i do
1. Build the libgpu library using the script
Makefile.ubuntu_gpu_opencl_amd
<http://lammps.sandia.gov/threads/binQ4bRDBFQGO.bin>
2. Build the Lammps using the Makefile Makefile.ubuntu_parallel
<http://lammps.sandia.gov/threads/binnzZOqmnDPe.bin>
The only thing that I changed was the folder , my folder was ./x86 instead of ./x86_64
after building the lammps I got the binary file and I could run a parallel simulation on my machine.
but when I try to run an example from the lammps/examples/gpu
i get an error
mpirun -np 4 ../../src/lmp_ubuntu_gpu_opencl_my -sf gpu < in.gpu.melt.2.5
//LAMMPS (30 Sep 2013)//
//Please see the log.cite file for references relevant to this simulation//
//Lattice spacing in x,y,z = 1.6796 1.6796 1.6796//
//Created orthogonal box = (0 0 0) to (67.1838 67.1838 67.1838)//
// 1 by 1 by 1 MPI processor grid//
//Created 256000 atoms//
//- Using GPGPU acceleration for lj/cut://
//- with 1 proc(s) per device.//
//- with OpenCL Parameters for: GENERIC//
//GPU 0: Intel(R) Core(TM) i3 CPU M 380 @ 2.53GHz, 4 cores, 3.5 GB, 2.5 GHZ (Single Precision)//
//Initializing GPU and compiling on process 0...Done.//
//Initializing GPUs 0-1 on core 0...Done.//
//OpenCL error in file 'geryon/ocl_timer.h' in line 106 : -7.//
//application called MPI_Abort(MPI_COMM_WORLD, -1) - process 0//
the same thing happens if I use the ../../src/lmp_ubuntu_gpu_opencl_my -sf gpu < in.gpu.melt.2.5 command.
What is wrong with ocl_timer.h??? Please tell me whether you may have any ideas about this?
I am attaching the ocl_timer.h, and makefiles
Thank you,
Vasiliy.
Makefile.mylinux_opencl_amd (561 Bytes)
Makefile.ubuntu_gpu_opencl_my (1.43 KB)
ocl_timer.h (4.34 KB)
