Hello all
Following the documentation instructions for installing ovito as a conda package results in the following error:
Solving environment: failed
LibMambaUnsatisfiableError: Encountered problems while solving:
- nothing provides __glibc >=2.28,<3.0.a0 needed by libcurand-10.3.10.19-h676940d_1
Could not solve for environment specs
The following packages are incompatible
└─ ovito =3.15.2 * is not installable because there are no viable options
├─ ovito 3.15.2 would require
│ └─ visrtx_ovito =0.13.3 *, which requires
│ └─ libcurand >=10.3.9.90,<11.0a0 *, which requires
│ └─ __glibc >=2.28,<3.0.a0 *, which is missing on the system;
└─ ovito 3.15.2 conflicts with any installable versions previously reported.
I am performing the installation on a newly created (empty) environment. It is not clear to me if the glibc component that is apparently missing should be installed from another conda package or it should already be present in my system, and if so how would one go about adding to a system without root privileges?
Thank you in advance
Christos
