Can't reach the target temperature
Hi everybody,
I have some simulations in the Berendsen’s thermostat and barostat. I have an thermal treatment for the system, from 100K to 10000K. But, it’s cannot reach to the target temperature. So, it’s maybe due to the damping parameter?
Thanks.
Hi everybody,
I have some simulations in the Berendsen's thermostat and barostat. I have
an thermal treatment for the system, from 100K to 10000K. But, it's cannot
reach to the target temperature. So, it's maybe due to the damping
parameter?
my crystal ball says it is due to sunspots.
I have a alpha-quartz system, about 500 atoms initially. I want to do the simulation to obtain amorphous silica. I used the BKS and Coulomb potentials for the system. I was first equilibrated at 300K and the pressure 1 bar. Then, the temperature will be increased to 10000K to obtain a molten state. The daming parameters I used were 100 fs for the thermostat and 10000 fs for the barostat.
the barostat.
and what does this tell us? still not a thing!
What is the timestep you used for the simulations?? What ensambles exactly?? Boundary conditions?? Specific boundary config. , if any?? How long did you run your simulation??
Sagar
