I am trying to model interaction of cnt and pure Si (diamond). I have two silicon block and a sw-cnt in the middle along z direction, with periodic boundary in all directions.
I have two atom types, 1. Si, 2. C.
As I looked into previous forum posts, I came across several suggestions.
They are mainly:
Approach 1:
Use tersoff for all atom types.
pair_style tersoff
read_data cntsi_v1.lmp
pair_coeff * * SiC.tersoff Si C
I tried this and equilibrated the structure with NPT, NVT, 0.4 nanoseconds each. Firstly the nanotube becomes slightly misaligned with z axis, and stays there for the rest of the run. The temperature is nicely equilibrated at 300. But when I applied NVE for 0.4 nanoseconds, the temperature gradually dropped to 260 K at the end of run. Also Kinetic energy slowly drops.
Question: could this come from a bad input file? Or may be inappropriate relaxation time in NVT and NPT? I am using a Tdamp = 0.1 with metal units and Pdamp =1 and a time step of 0.001 (i.e. 1 fs)
Approach 2:
Use tersoff for Si-C and Si-Si interaction and airebo for cnt. This was discussed too, and the problem here was that since both airebo and tersoff are multibody potential , treating them like pair-wise additive potentials may not be a good idea. However, There are literatures using exactly this approach. (e.g. Zhang X. A Low-Frequency Wave Motion Mechanism Enables Efficient Energy Transport in Carbon Nanotubes at High Heat Fluxes. Nano letters. 2012-06;120618121952007 )
Question:
How could we do this in lammps (if at all)?
Approach 3:
Use tersoff or sw for silicon, airebo for cnt, lj/cut for Si-C interaction. The lj/cut pair coeffs can be obtained from Universal force field.
So, overall which approach is most realistic to model such a system?
Souvik.
