Dear Lammps users
I am trying to simulate polymer model where I want to introduce chain bending rigidity through some potential.
So is there any way of introducing it.
Thanks and regards
Dear Lammps users
Thanks and regards
Yes. Take a look at the angle potentials in lammps.
Dear Mrityunjay,
Hello Mrityunjay. To introduce chain bending rigidity, you can use angle_style cosine and the corresponding coefficients can be specified by using angle_coeff “angle types which angle_style is applied” "Energy parameter for bending rigidity"
Thank you.
Sincerely,
Masato Koizumi
Dear Masato
The angle style cosine works
Thanks and Regards
Hello Mrityunjay,
I just wish to remark that an angle potential is typically only used to introduce stiffness in chains which are very stiff (“wormlike” chains). Typically, in a chemically detailed model for a polymer chain (all atom or united atom, for example), the angle potential will more or less fix bond angles, and chain stiffness comes from the dihedral potential. In a less chemically detailed models (Kremer-Grest, for example) the chain-stiffness is typically coarse-grained out of the model leaving only bead-spring chains with excluded volume.
The angle potential may very well be appropriate for your model, but I thought it was worth clarifying in case your chains are not wormlike.
-David
