Hello!
I have a system in triclinic box saved in data-file. Box is actually almost hexagonal, i.e. two edges are equal, angle between them is 60 and other angles are 90. In lammps terms it means that xy ~ (xhi-xlo)/2, yz=xz=0.
I want to represent this system as orthorhombic one, to do it I just need to redefine boundary conditions and to remap atoms that are outside of the new box. New box has same volume as the old one.
I have tried several ways:
change_box command: it applies transformation matrix to atom coordinates according to the basis change, which distorts distances between atoms(at least it looks like this).
explicitly change box parameters in data-file
explicitly change box parameters in data-file and remap manually atoms into the new box
Both 2 and 3 lead to the lost atoms for bonds right after start.
So what is the easiest way to redefine box without distortion of atom positions? All I need is just to discard old boundary conditions and to add new ones with atoms remap into the new box.
Thanks!
Hello!
yz=xz=0.
1) change_box command: it applies transformation matrix to atom
if you leave out the "remap" option to the change_box command, it should
do what you want. you have to make certain, though, that your communication
cutoff is large enough, or you may lose atoms.
2) explicitly change box parameters in data-file
that should work for as long as your atoms have no image flags != 0
if you have an atomic system, simply using the set command to reset all
image flags to 0 is a workaround., but it will fail for systems with bonds.
3) explicitly change box parameters in data-file and remap manually atoms
into the new box
as noted above, you need to increase your communication cutoff with
comm_modify to make certain, that through the sudden change of box
geometry, atoms, which need to be rewrapped, are not suddenly located
outside the communication cutoff and thus get lost. the remapping in 3)
can be tricky if you also need to consider image flags.
