Dear Lammps Users,
I developed an input script to deform the simulation box (2D) and then perform stress calculations on a GRANULAR packing. I am using the September 2013 lammps version. But I am getting an error.
ERROR :
change_box all triclinic
ERROR: Cannot change_box after reading restart file with per-atom info (…/change_box.cpp:52)
Dear Lammps Users,
ERROR :
(../change_box.cpp:52)
Input script was :
read_restart ./restart
pair_style gran/hooke/history 1.0 0.0 1.0 0.0 0.0 1
pair_coeff * *
neighbor 0.2 bin
neigh_modify every 1 delay 0 check no
velocity all set 0.0 0.0 0.0 units box
reset_timestep 0
fix lebc all deform 1 xy erate ${mystrainrate} remap x
I found some suggestions in the mail list to fix this error but i couldn't
understand very much.
i.e.,
Cannot change_box after reading restart file with per-atom info This is
because the restart file info cannot be migrated with the atoms. You can get
around this by performing a 0-timestep run which will assign the restart
file info to actual atoms. I am not clear myself what does it means by
0-timestep run means ?
it means to use the command:
run 0
that will execute the setup phase of a run, but not actually run any
timesteps that advance the positions.
