Dear,
In a simulation I generate dump every 100 time steps from step 3002000. All good with this, snapshoot generated are :
3002000
3002100
3002200
6002000
total: 30000 snapshot. Now I intend to calculate the rdf from the rerun command. However, when I create the dump does not take account Nevery parameter of fix ave/time: “The final averaged quantities are generated on timesteps that are a multiple of Nfreq”.
Therefore I can not use the option “ave one” of fix ave/time to average 30000 snapshot, because of missing 20 snapshot to get the average to step 6000000. I can only averaging 20,000 maximum snapshot , wasting 10000.
This I can solve simulation running again , however, it involves a long wait. Change the steps manually see it complex, the file size approx 100GB. I was thinking of something like reset to flight time steps the dump file , to 0,1,2,3 , … 30000. However, with the rerun command I do not see how to do this. Also probe the start option start of ave/time but got no results.
The ave running option could partially solve the problem, Nfreq=100, but my intention is to average with ave one
Any recommendation?
Regards
Dear,
3002000
3002100
3002200
6002000
parameter of fix ave/time: "The final averaged quantities are generated on
timesteps that are a multiple of Nfreq".
Therefore I can not use the option "ave one" of fix ave/time to average
to 0,1,2,3 , ..... 30000. However, with the rerun command I do not see how
results.
Any recommendation?
if you read the trajectory via the vmd molfile plugin for LAMMPS
instead of the native reader (requires installing the USER-MOLFILE
package) and the corresponding molfile plugin binary from a compatible
VMD installation), the timestep field should be ignored (i think) and
then the desired renumbering would happen.
Mr. Axel thanks for the suggestion. I will review the package you mentioned.
