change
i made a mistake to type code here. it works but in a wrong way.i try to
learn more about variable.it is part of may code:
fix 1 all nvt/asphere temp 10.0 10.0 0.007
run 1000
variable k loop 10
label loop1
variable t equal 10*10^(-k)
velocity all scale t
#fix 2 all nvt/asphere temp t t 0.007
run 1000
next k
jump in.lammps loop1
untitled-[2] (8.73 KB)
​it is *still* very wrong. i gave you some suggestions previously. you
should also spend some time working through the tutorial material about
LAMMPS and study the examples.
it appears that you are trying to immediately do a complex research
assignment without having any experience in LAMMPS (and little if any
experience in MD and statistical thermodynamics). this is not going to work
out. you have to take things in smaller steps. if you don't change your
ways, you are unlikely to get much help from the mailing list.
