Greetings!
When I download a json file form XRD JSON button, the file name only contains the ID, element used as X-ray source and the technique XRD.
Inside the file, the following data is available: {“meta”: [“amplitude”, “hkl”, “two_theta”, “d_spacing”], “created_at”: “2020-09-03T18:21:48.286063”, “wavelength”: {“element”: “Cu”, “in_angstroms”: 1.54184}}
Followed by the pattern.
When programming a script, it is not easy to obtain other information, such as the elements, the structure, formula, “pretty_formula”, etc.
I’d like to request that either the file contains the pretty_formula in the name or inside the file and, if possible, the structure. Each mp card available has a web page and the web page’s title contains the necessary information. For example, for mp-1206743: HfS (hexagonal, P-6m2, 187), the title of the page is: mp-1206743: HfS (hexagonal, P-6m2, 187)
If this could be present in the XRD JSON filename as: mp-1206743_HfS_(hexagonal, P-6m2, 187)_xrd_Cu.json, for the Cu source as an example, it would be awesome! or inside the file.
Thank you!
