Dear Lammps users,
I am trying to simulate Batio3 crystal rotated at various degrees: (15, 30, 45...). I could do the rotation of the crystal from original 100 crystal and then changing the simulation box size according to the size of the model. But after the rotation and changing the box size , when I tried to run an energy minimization it says : it cant compute MSM because the system is not charge neutral.
How can I make the system charge neutral? Do I need to delete some atoms that contribute to the charge imbalance or there is some other way around?
Here is the script:
# barium titanate using buckingham potential mode 1 fracture
boundary p m p
atom_style charge
neighbor 0.3 bin
neigh_modify delay 5
# create geometry
lattice custom 3.999 origin 0.0 0.0 0.0 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1 &
basis 0.0 0.0 0.0 &
basis 0.5 0.5 0.5 &
basis 0.0 0.5 0.5 &
basis 0.5 0.0 0.5 &
basis 0.5 0.5 0.0 &
a1 1.0 0.0 0.0 &
a2 0.0 1.0 0.0 &
a3 0.0 0.0 1.00925231307827
region box block -20 20 -20 20 -0.5 0.5
region simbox block -20 20 -20 20 -0.5 0.5
create_box 3 simbox
create_atoms 1 region box &
basis 1 1 &
basis 2 2 &
basis 3 3 &
basis 4 3 &
basis 5 3
mass 1 137.327
mass 2 47.867
mass 3 15.9994
# rotating the simulation box and atoms
group inibox region box
displace_atoms inibox rotate 0 0 0 0 0 1 45
region outbox block -4 4 -4 4 -0.5 0.5 side out
group outbox region outbox
delete_atoms group outbox
change_box inibox x final -4 4 y final -4 4 z final -0.5 0.5 units lattice
#buckingham and coulombic potential
#pair_style buck/coul/msm 12
pair_style buck 5
pair_coeff 1 1 0.0 10.0 0.0
pair_coeff 1 2 0.0 10.0 0.0 #Ti-Ba
pair_coeff 1 3 1214.4 0.352200 8.0 #Ba-O
pair_coeff 2 2 0.0 10.0 0.0 #Ti-Ti
pair_coeff 2 3 877.2 0.38096 9.0 # Ti-O
pair_coeff 3 3 22764.0 0.1490 43.0 # O-O
#kspace_style msm 1.0e-4
# define groups
#region 1 block INF INF INF -6 INF INF
#group lower region 1
#region 2 block INF INF 4 INF INF INF
#group upper region 2
#group boundary union lower upper
#group mobile subtract all boundary
region crack block -0.5 0.5 -0.5 0.5 -0.5 0.5
group crack region crack
delete_atoms group crack
group Ba type 1
group Ti type 2
group O type 3
#set group O charge -2.0
#set group Ti charge 4.0
#set group Ba charge 2.0
compute stress all stress/atom
compute stress1 all reduce sum c_stress[1]
compute stress2 all reduce sum c_stress[2]
compute stress3 all reduce sum c_stress[3]
compute stress4 all reduce sum c_stress[4]
compute stress5 all reduce sum c_stress[5]
compute stress6 all reduce sum c_stress[6]
#dump eqli all xyz 10 batio3i.xyz
# initial velocities
#velocity lower set 0.0 -0.5 0.0
#velocity upper set 0.0 0.3 0.0
# fixes
fix 1 all nve
#fix 2 boundary setforce NULL 0.0 0.0
# run
timestep 0.003
thermo 10
#dump eql2 all custom 10 id type x y z batio3.file
#dump ID group-ID style N file args
dump eql2 all custom 10 batio3.* id type x y z
dump eql all xyz 10 batio3.xyz
dump 1 all cfg 500 stressimage_*.cfg mass type xs ys zs c_stress[2]
run 2000
Best Regards
Sakib
