Dear LAMMPS Users
I have intended to observe charge surface impact on droplet. In order to omit the surface charge’s impact in Z direction, the slab correction has been assigned. Unfortunately, the charged surface still influences on the droplet in Z direction and a cylindrical shape is formed in z direction.
(The surface is formed in xy-plan )
The attached photo is extracted after 10000 timesteps.
I will appreciate any suggestion.
Thank you
Sincerely
Reza.
Dear LAMMPS Users
omit the surface charge's impact in Z direction, the slab correction has
i think you are misunderstanding what the slab correction does. it
will remove dipole interactions between *periodic copies* of the slab.
that is it.
and for that to be meaningful, you'll have to make certain, that your
system is neutral, e.g. by converting your charged slab into a
polarized slab.
but even in that case, your polarized slab *will* impact your system.
your overall description is far to vague to give any recommendation
and your picture is not very helpful either, as it is by no means
self-explanatory and particularly it doesn't even show the required
separation between periodic copies of the slab system.
Thank you Axel
units real
atom_style full
boundary p p f
special_bonds lj/coul 0.0 0.0 0.0
pair_style lj/cut/coul/long 10 15
bond_style harmonic
angle_style harmonic
kspace_style pppm 1.0e-5
kspace_modify slab 5.0
neighbor 2.0 bin
fix sheet Cgraphene setforce 0.0 0.0 0.0
fix sheetup CgrapheneUp setforce 0.0 0.0 0.0
fix top CgrapheneUp wall/reflect zlo 158
fix fixnvtf fluidbox nvt temp 298.13 298.13 100.0
fix fixshake fluidbox shake 1.0e-5 20 10 b 1 2 3 a 1 2
simulation box :
-75 75 xlo xhi
-75 75 ylo yhi
-30 180 zlo zhi
Droplet consists of 7000 water molecules, sheet is located on 0.0(A) in z
direction and upper wall is located on 158 (A) in z direction.
Is there any way to simulate this situation?
Sincerely,
Reza
