CHARMM TIP3P
For regin TIP3P-CHARMM water model, I wrote the input file like this:
units real
atom_style full
read_data 00.data.lammps
group water type 1 2
bond_style harmonic
bond_coeff 1 450 0.9572
angle_style harmonic
angle_coeff 1 55 104.52
pair_style lj/cut/coul/long 12.0
pair_coeff 1 1 0.1521 3.15061 12.000
pair_coeff 1 2 0.0836 1.77530 12.000
pair_coeff 2 2 0.0460 0.40000 12.000
kspace_style pppm 0.0001
special_bonds lj/coul 0.0 0.0 0
neighbor 2.0 bin
neigh_modify delay 0 one 2000 check yes
timestep 1.0
thermo_style custom step temp etotal
velocity water create 300.0
min_style cg
min_modify dmax 1.0
minimize 0.01 0.001 1000 1000000
thermo_style custom step temp etotal press
thermo_modify flush yes line one
thermo 100
fix regidwater water shake 0.0001 10 10 b 1 a 1
fix 2 water npt temp 300.0 300.0 100.0 z 1.00 1.00 1000.0
run 500000
unfix 2
But I think I should not use both 'fix SHAKE ’ and harmonic bond/angle at the same time.
Hangyan
2011-09-23
2011/9/23 physics.hangyan.chen <[email protected]...>:
But I think I should not use both 'fix SHAKE ' and harmonic bond/angle at
the same time.
you _have_ to. how do you think fix shake would otherwise know what
your desire bond length or angle would be?
since you are also running minimizations, you should increase the
force constants on both (at least during minimization, i use a factor
of 100) so that the water molecules don't stretch and bend too much.
in combination with shake, the force constants have no meaning.
