Dear LAMMPS users,
I am trying to mix heptadecane with graphene in CHARMM FF and conversed subsequently to the LAMMPS data file using charmm2lammps v1.9.2. Graphenes are located randomly in heptadecane.
Firstly, I pack the heptadecane and graphene using packmol. Subsequently, I try to generate psf file (Mixed-Hepta-Graphene.psf) and pdb (Mixed-Hepta-Graphene.pdb) file in VMD using top_all36_cgneff.rtf and top_all36_lipid.rtf for graphene and heptadecane, respectively. I try to generate the LAMMPS data file separately using charmm2lammps and obtain two LAMMPS data files (LAMMPS-all36_cgenff.data & LAMMPS-all36_lipid.data).
But, the results show as follows:
Generating LAMMPS data using all36_cgenff:
perl charmm2lammps.pl all36_cgenff Mixed-Hepta-Graphene
Info: using MixedHeptaGraphene1.pdb instead of MixedHeptaGraphene1.crd
Info: lx not set: will use extremes
Info: ly not set: will use extremes
Info: lz not set: will use extremes
Info: creating PSF index
Info: converting atoms
Info: converting bonds
Warning: bond parameter 1 for [ ] was not found
Info: converting angles
Warning: angle parameter 1 for [ ] was not found
Info: converting dihedrals
Warning: dihedral parameter 1 for [ ] was not found
Info: converting impropers
Info: conversion complete
Generating LAMMPS data using all36_lipid:
perl charmm2lammps.pl all36_lipid Mixed-Hepta-Graphene
Info: using MixedHeptaGraphene2.pdb instead of MixedHeptaGraphene2.crd
Warning: 5 atom types present, but only 4 pair coeffs found
I am also wondering how to generate LAMMPS data using two different Topology files (top_all36_cgneff.rtf & top_all36_lipid.rtf) for the mixture. Is it possible to generate single LAMMPS data using two different topology files?
All attached files are saved in the following link: LAMMPS - Google Drive
I will be so grateful for any helpful comments and suggestions.
Regards,
Togi
