Prelims: we tried charmm2lammps to convert an existing NAMD project to
lammps, and it succeeded without warnings.
We now try a slightly larger project, and see:
$ perl charmm2lammps.pl nachr nachr-uS5chol2ach
charmm2lammps v1.9.1 (c)2005-2016
Info: using nachr-uS5chol2ach.pdb instead of nachr-uS5chol2ach.crd
Info: lx not set: will use extremes
Info: ly not set: will use extremes
Info: lz not set: will use extremes
Info: creating PSF index
Info: converting atoms
Info: converting bonds
Warning: bond parameter 1 for [ CRL1] was not found
Warning: bond parameter 2 for [ CRL2] was not found
Info: converting angles
Warning: angle parameter 1 for [ CRL1 CRL1] was not found
Warning: angle parameter 2 for [ CRL1 CRL2] was not found
It looks as though there is a blank as one of the "atoms" in each
warning. I'm guessing that as NAMD is happy with those input files,
it is somehow more lenient than charmm2lammps? I am having a hard
time figuring out what is missing, as the warning happens after
"everything" is parsed, and noting which lines have empty parameters.
Any clues on how to debug this?
Best wishes,
Patrick
