Dear LAMMPS users,
I’m a beginner level user of the LAMMPS software. And I’ve builded a data file of SiO2_Li (topology file) structure with the help of a Matlab code, arranging all the data in the LAMMPS acceptable data file format. And now I’m trying to run it, just to check the structure by generating a CFG file at step 0(so I can open it in OVITO), but due to some unknown reasons it’s generating no file at all, leaving me without any clue of the error. As of now, I just wanted to check the structure that I generated with my Matlab code. With the given circumstances, I’m not able to find whether the problem is with my data file or somewhere else i.e. input file etc. So my question is, is there any way to open the data file except with LAMMPS so that I can see the actual structure that I had created.
Thanks a lot for your time, and efforts.
Dear LAMMPS users,
you can use the write_dump command to write out a dump frame without a run.
you can also use write_data and compare the generated data file with
your original. for small systems, this is not too difficult.
the topotools plugin included in VMD can read LAMMPS data files:
https://sites.google.com/site/akohlmey/software/topotools/topotools---documentation#TOC-readlammpsdata-file-name-atom-style-
